Commvault sso no longer works
  • January 23, 2024
  • 161 views
our sso no longer works and the current local CommVault password is not known is there a way of getting into the CommCell to reset the ad sso connect password so that it can authenticate with AD.
e.g is there a way of resetting the AD password and account it uses to via command prompt or a way via the registry to get to connect to AD.
Best answer by Collin Harper
Hello @backing up active directory
It might be best to get a case opened with our Server Team to help you re-gain access to the CommCell.
Thank you,
Collin
  • January 23, 2024
Thank you,
Collin
is there a specific way to raise a call with server team?
When you classify the case it will automatically route to the correct Team based on the classification selected.
Thank you,
Collin
