Creating a Subclient using command line
  • September 4, 2022
  • 7 replies
  • 786 views
Forum|alt.badge.img+8
I’m trying to create a subclient using command line below but im stuck with the idataagent name which says subclient: Error 0x303: Unsupported iDataAgent Type VirtualServerAgent which i try to type :
“Virtual Server”
Virtual_Server
VirtualServerAgent
VSA
qcreate subclient -c client -a dataagenttype -b backupset -i instance -n subclient -sp storagepolicy -f content1
Best answer by Graham Swift
Hello @Muhammad Abdullah, Whilst qoperation mentioned above will work, the agent syntax is documented in various sections and link to the following page. So you want to use:
Q_VIRTUAL_SERVER
See here for more details on the agent types to use in these commands.
https://documentation.commvault.com/2022e/expert/45467_command_line_faq.html#b45468_what_are_argument_values_used_for_agent
Example below working as you may need:
Just check if the content works as in my lab I had to specify a valid VM but nothing is added to the content.
Jos Meijer
Forum|alt.badge.img+21
  • Community All Star
  • September 4, 2022
Hi @Muhammad Abdullah
I would normally use the following method (assuming this is for VMWare):
https://documentation.commvault.com/2022e/expert/32414_creating_subclient_vmware_command_line.html
But deriving from this command could it be that you need to use a single quote for ‘Virtual Server’ ?
Not sure if this agent is supported with qcreate though.
chrisknows
Challenger
  • Challenger
  • September 4, 2022
@Jos Meijer is correct, you should use qoperation execute in conjunction with the xml file.
Graham Swift
Forum|alt.badge.img+13
  • September 4, 2022
Q_VIRTUAL_SERVER
Onno van den Berg
Forum|alt.badge.img+24
Funny to see Q_, which originates from the time in where the product was called QiNetix and the company name was written as CommVault, is still seen so much throughout the product.
Graham Swift
  • September 5, 2022
Showing your age there Onno :) don’t miss the Galaxy part as well, still seen in many places ;)
and for posterity, we still have a page with it all spelled out: https://ir.commvault.com/news-releases/news-release-details/commvault-launches-next-generation-qinetix-software-address
i have tried the xml file and it worked thanks =)
Q_VIRTUAL_SERVER
Thank you @Graham Swift
this is what i was looking for =)
