custom package silent install
  • 13 April 2021
  • 2625 views
Badge +14
I try to deploy a custom package with answer file.Then I executed the package with this command :
start /wait c:\Sources\CustomPackageLocation_Win_FS\WinX64.exe /play install.xml /silent
all is automatically filled by the answer file fine except at the beginning, I need to confirm manually this checkbox.
Thanks !
Best answer by Stuart Painter 13 April 2021, 09:59
Badge +15
Hi @Bloopa
Please can I check what process you are using for the custom package:
  • Self-extracting executable, or
  • A package containing the answer file
Reviewing Installing a Custom Package Using Third-Party Software:
Review the following requirements:
  • For Windows custom packages, the package must be either a self-extracting executable file or a package that includes the answer file. If the package consists of only the answer file, you must have a separate installation package on which you can run the file. The answer file needs the software binaries from an installation package to install the software.
For Windows custom packages:
  • If the package is a self-extracting executable file, use the following command:
    CustomPackageName.exe /silent /install /silent /authcode authcode
  • If the package is a folder that includes the answer file, use the following command:
    start /wait Setup.exe /play install.xml /silent /authcode authcode
Stuart
