DDB Reconstruction
  • June 4, 2022
  • 312 views
Hello ALL,
Currently running a DDB reconstruction and encountered this
Failed to Copy or verify Chunk [1123876] in media [CV_MAGNETIC], Storage Policy [xxxxxx], Copy [xxxxxx], Host [xxxxxx], Path [G:\CV_MAGNETIC\V_363047], File Number [17], Backup Jobs [ 46145]Access to the file/media denied. Access to the file/media denied. Source: xxxx, Process: DDBRecovery
Path can be access on the media agent.
Best answer by Afeez
Hi @Emils
Thanks.
Checked the security settings on the path and noticed the user for commvault was not in the list. I added it and seems ok now.
But now error has changed to failed to insert record on some chunks
Emils
  • June 6, 2022
Hi @Afeez
Access denied errors typically occurs when one of the following occurs:
  1. The service account used for Commvault does not have access to the Log + Base Directory nor the MagLib Path
  2. The documented AV exclusions are not in place
  3. A storage related errors which is stopping access to the Chunk and its associated blocks which may not reside in the same location mentioned in the error (G:\CV_MAGNETIC\V_363047)
Can you please check AV exclusions are in place and any accounts used as service accounts have read/write access to all mountpaths, Log folders & base?
  • June 6, 2022
Hi @Emils
Thanks.
