Disaster Recovery - VM failover menu issue
  • April 3, 2023
  • 97 views
Michael Woodward
Certified Expert
We have VM Periodic (classic) replication setup for some VM’s in an environment, the menu that pops out to initiate the failover scenarios does not display properly if you have limited VM’s in the replication group. The menu slides out but is then hidden behind the Replication Monitor pane.
Example below of a replication group with a single VM in it:
If a replication group has multiple VM’s in there (in this case 4) the menu displays correctly:
Seeing this issue in Chromium based browsers.  Apart from resizing the window to something very narrow/tall (like example below):
Is there a potential fix for this?
Best answer by Sebastien Merluzzi
@Michael Woodward ,
Development has confirmed, this issue is there but in the current angular screens we can't fix it.
In case when you have one vm then we should right click on the vm and then go to failover and then perform the operations.
Hi @Michael Woodward
I am checking in the lab and also spoke to Development for them to check.
Can you confirm the full version you have please?
Sebastien
Michael Woodward
Certified Expert
Sebastien
Hi @Sebastien Merluzzi I’ve noticed this behavior in my lab and a production environment both on 11.28 (different MR’s) I’m currently updating my lab to 11.30 to validate.
Michael Woodward
Certified Expert
Have just tested lab at 11.30.25 - same issue:
@Michael Woodward ,
Michael Woodward
Certified Expert
Thanks @Sebastien Merluzzi Confirmed that workaround. Thanks for the quick responses!
