Trying expert view in the documentation, but after clicking sign in , there is an internal server error. Link I used: https://developer.commvault.com/11.22/expert/index.html
Known problems @ commvault?
Best answer by Mike Murawinski
View originalTrying expert view in the documentation, but after clicking sign in , there is an internal server error. Link I used: https://developer.commvault.com/11.22/expert/index.html
View originalHi
Thank you for letting us know, I am seeing something similar.
I can access Expert Documentation internally, but externally there appears to be an issue with authentication as login is required to read Expert content.
I’ll raise this internally and let you know once this is resolved.
Stuart
Hi
Looks like authentication is working again now, are you able to login?
This came online whilst I was checking internally, even before I flagged with the Documentation team, so looks like a brief temporary issue.
Stuart
not working yet.
But, https://developer.commvault.com/11.22/expert/index.html => sign-in not working
https://developer.commvault.com/11.21/expert/index.html => sign-in not working
https://developer.commvault.com/11.23/expert/index.html => sign-in WORKS
Ah yes, I’m seeing the same behaviour. My tests earlier were successful with FR23.
I have raised this with the Documentation team.
Stuart
Hi
I am now getting successfully redirected to login for FR21, 22 and 23.
Are you able to login successfully to Expert Documentation now?
Stuart
Hi
Stuart
Yes, it works.
Hi
Thank you for bringing this to our attention. There was an issue authenticating expert documentation from certain Commvault subdomains. We fixed the issue, and now you should be able to log in to expert documentation from documentation.commvault.com, docs.commvault.com, and developer.commvault.com.
Apologies for the inconvenience. Please do let me know if you experience any further issues with the documentation site.
Mike
