Easy way of checking, if a provided Hotfix is included in the MR
  • November 4, 2021
  • 266 views
Forum|alt.badge.img+5
Hi All,
we are looking for an easy way to check, if a Hotfix provided from support is included in the upcoming MR Release.
In the past we could compare the numbers, but something changed and now the numbers doesn’t match anymore.
Currently we want to check if the v11SP24_Available_Diag3055-Hotfix already made it into the MR 16
But the Number doesn’t match anything from the
listed https://documentation.commvault.com/11.24/assets/service_pack/updates/11_24_16.htm,
Anybody knows, who to translate the Diag-Patch Numbers?
Or do we have to create a Ticket with Support to get it checked?
Best answer by Scott Moseman
I’m not sure customers have a way to correlate a Diag # with a HotFix #.
You could probably ask Support, or maybe the SE on your account team.
I checked the above Diag and the official HotFix has not been created yet.
Since there’s no official HotFix yet, it’s obviously not included in any MRs.
Scott
Scott Moseman
Forum|alt.badge.img+23
  • November 4, 2021
Scott
@ADN GMBH , you can always just start a thread here and I’ll look it up for you.  We can check the backend side and track it through for you.
  • December 13, 2021
Is there any updates on the hotfix?
Is it now part of an MR?
Looks like it is in 11.24.24 (credit to @Scott Moseman who found this for me :sunglasses: )
