Enable ping on hypserscale
  • Jul 2, 2024 2:59 PM UTC
  • 381 views
I need to enable ping to hyperscale nodes for monitoring purposes.
Is there a specific way to do it or standard linux commands need to be used?
Best answer by Chris Hollis
Hi @Sandy11
My research indicates the following commands can be run to enable ping:
firewall-cmd --zone=block --add-icmp-block-inversion --permanent
firewall-cmd --zone=block --add-icmp-block=echo-request --permanent
systemctl restart firewalld
Note, each line is a seperate command.
Feel free to give this a go and let me know how it goes.
Chris
Chris Hollis
  • Jul 4, 2024 2:58 AM UTC
Hi @Sandy11
Chris
  • Jul 4, 2024 6:18 PM UTC
Thanks, it worked perfectly.
