Error 91:32 When Trying to Restore a VM
  • March 29, 2021
  • 31 replies
  • 3848 views
Show first post
Hey @tsmtmiller , hope all is well!
Any update from VMWare?
Thanks in advance!!
  • June 9, 2021
Thanks in advance!!
Hello, I am finalizing a test to see if the solution worked.
Sounds good (and hopeful)!
  • June 9, 2021
Thanks in advance!!
VMware came back with an MTU size issue causing the datastore snapshots to mount but not unmount. This was breaking the restores. The VMkernel Adapter for Backups had the MTU size set to 9000. The Virtual Switch for Backups had a MTU setting of 1500. We changed the MTU’s to match. Once we did this, I was able to manually mount and unmount the snapshots and finally actually perform a full restore of the VM.
Very nice and detailed!  Thank you @tsmtmiller  for sharing for all posterity!
