Hello all!
I am wondering if there is a way to check “storage” on servers, which are a part of backup in Commvault.
Reason:
In our company - we as a backup team does not have direct access to hosts, and sometimes it took ages to find someone responsible for server to do some checks…
Quesion:
If there is File System agent installed on server - is there a way to check things like “total size, consumed space, free space”? On both Linux and Windows machines?
It would help us a lot, especially while restoring out of place DBs.
I am asking because i have found that Oracle agent is doing some checks while preparing restore:
I have like thousands of ideas how it could improve our quality of work...
Any ideas?
While it might not exist natively, you could leverage the Workflow Engine to run a script on the Client prior to initiating a restore, etc.
As a quick and dirty example, you can use a Workflow to call the following PowerShell command to return the DeviceID, Disk Size, and Free Space for a Windows-based Client, and then output it to a popup
Get-WmiObject -class Win32_logicaldisk | format-list DeviceID, @{n="Size";e={[int]($_.Size /1GB)}}, @{Name="Free Space";e={[int]($_.FreeSpace /1GB)}}
Many thanks for your support!
Unfortunately, we might not be allowed to run such a script remotely on machines - possible security breach 😅
Nevertheless, it might be helpful for someone else looking for similar solution!
Have a great day!
