Fix for granular restore for block-level backup (SP24/FR24)
  • November 16, 2022
  • 83 views
Hello Commvault Community,
Some time ago I ran a case in Commvault support for SP20, for a problem with granular data recovery for BLB. Incident 210702-97
The issue has been resolved with hotfix: SP20_PreRelease-4648-BIN
After upgrading the environment to SP24, the problem was noticed again when trying to granular restore for BLB.
Here I have a request for you to check if this fix is included in SP24 or is there a need to raise a ticket in Commvault support asking for rewriting this fix for SP24?
Kamil
Best answer by Mike Struening
Hi @Kamil , I can track that down for you.
The form ID is conveniently 4648.
I can see it was added officially to 11.20.85, but it does not exist in any other Feature Release.
Open a new support case, share all of this information and request an 11.24.  I don’t want to speculate as to why it was not included (could have been intended for 11.24.0?).
  • November 17, 2022
Hi @Mike Struening
As you recommended - I escalated the problem to Commvault support. (Incident 221117-213)
I'll let you know here in this thread when they figure something out :)
Kind Regards,
Kamil
Appreciate the follow up!
