How to specify subclient contents for Linux file systems as '/'
  • 1 July 2022
  • 61 views
Badge +3
Hello
When setting the subclient contents of the Linux Filesystem Agent in the V11 SP16 environment, I would like to know how to set it to the '/' path.
It was not added by entering / in the add paths, and it was not added by clicking add after selecting the Agent Server name in Browse.
Best answer by Stuart Painter 1 July 2022, 08:51
Badge +15
Hi @tmyoo
Default content for a File System subclient is “\”.
Creating a File System Subclient.
Please check any subclient policies, global filters or filters defined at group level that may be excluding content on a particular client - otherwise the default is to include all data on the file system.
Please also be aware that the same content cannot be included in multiple subclients for the same backupset. So, if you have more than one subclient configured on a client, content protected in subclient A will automatically be excluded from subclient B.
Stuart
