Greetings to All,
I am facing the issue that we have encountered with a disk on our Hyperscale node. Upon checking the system log, we have found that the disk has failed. However, in the ILO, all disks are showing as green.
I would greatly appreciate your help in resolving this issue
/var/log/messages:
Jun 22 07:59:10 homlab-dth kernel: sd 2:0:19:0: Power-on or device reset occurred
Jun 22 07:59:10 homlab-dth kernel: sd 2:0:19:0: [sdw] FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=1s
Jun 22 07:59:10 homlab-dth kernel: sd 2:0:19:0: [sdw] Sense Key : Not Ready [current] [descriptor]
Jun 22 07:59:10 homlab-dth kernel: sd 2:0:19:0: [sdw] Add. Sense: Logical unit not ready, notify (enable spinup) required
Jun 22 07:59:10 homlab-dth kernel: sd 2:0:19:0: [sdw] CDB: Read(16) 88 00 00 00 00 05 86 03 a8 a8 00 00 00 88 00 00
Jun 22 07:59:10 homlab-dth kernel: blk_update_request: I/O error, dev sdw, sector 23723223208
Jun 22 07:59:10 homlab-dth kernel: sd 2:0:19:0: [sdw] CDB: Read(16) 88 00 00 00 00 05 86 03 a9 b8 00 00 00 f0 00 00
Jun 22 07:59:10 homlab-dth kernel: blk_update_request: I/O error, dev sdw, sector 23723223480
Jun 22 07:59:10 homlab-dth kernel: sd 2:0:19:0: [sdw] CDB: Read(16) 88 00 00 00 00 05 86 03 ac 60 00 00 00 88 00 00
Jun 22 07:59:10 homlab-dth kernel: blk_update_request: I/O error, dev sdw, sector 23723224160
Jun 22 07:59:16 homlab-dth swatch: calling HP led utils
Jun 22 07:59:16 homlab-dth swatch: xfs_do_force_shutdown for xfs is ['sdw']
Jun 22 07:59:16 homlab-dth swatch: ['/hedvig/d23:sdw']
Jun 22 07:59:16 homlab-dth swatch: swatch mode is nodelay
Jun 22 07:59:16 homlab-dth swatch: swatchmode is nodelay
Jun 22 07:59:16 homlab-dth swatch: ['f188ee3b525ad54b5ca$21:/hedvig/d23:sdw']
