Ignore pg_dump
  • May 10, 2021
  • 326 views
During the backup I have issue: /opt/PostgreSQL/8.3/bin/pg_dump: unrecognized option `--lock-wait-timeout=60000'
Commvault  11.20.46
Postgres SQL 8.3
I know that the new version of Comvault no longer supports this version of the databases
I have a question, is it possible to modify the pg_dump command in Commvault? (to omit an unrecognizable option) Alternatively, how can the following problem?
Best answer by Sunil
Hi @kszaf
There is no way to skip this argument. Also, it’s not advisable to backup PostgresSQL 8.3 using v11 client. You can install a v10 client pointing to v11 CommServer to backup this version.
Sunil
Meera
Forum|alt.badge.img+9
  • May 10, 2021
Hi ,
There is no workaround for this. There is no provision to remove a default parameter passed with pg_dump .
How many postgresql instances do you have with version 8.3? and what is the upgrade plan? lock-wait-timeout was introduced in postgres 8.4
Meera
Sunil
Forum|alt.badge.img+16
  • May 10, 2021
Hi @kszaf
Sunil
  • May 13, 2021
Thanks for help!
  • May 13, 2021
Thanks for help!
