Index Cleanup start
  • May 10, 2022
  • 575 views
Hi All,
i had the following challange:
Index and DDB are using same SSD ( Yes i know… )
Index is using 1,96TB. Settings are:
Retain index for : 50
Generate alerts when free space falls below : 50GB
Take the Index offline when free space falls below : 10GB
Cleanup until free space is at least: 10 percent
Now we have to move the index+ddb to new disk which is smaller than the actually disc.
I Change the Settings to:
Retain index for : 20
Cleanup until free space is at least: 50percent
So how can i trigger the cleanup ?
Best answer by SSchmidt
cycle services triggerd directly the cleanup :) So we had directly freespace
  • Certified Expert
  • May 10, 2022
  • Challenger
  • May 10, 2022
hi @SSchmidt
First question : are you using indexing v1 or v2 ?
In the doc below you can find bit of details regarding index cleanup routines : how it’s triggered, behaves..
https://documentation.commvault.com/11.25/expert/59423_online_help.html
Hope this helps.
Otherwise you can restart services on your MA.
Laurent.
