IntelliSnap Protection for VMs on VSAN
  • March 31, 2022
  • 835 views
Forum|alt.badge.img+5
In the following site IntelliSnap Protection for VMs on VVol or VSAN/VxRail Datastores (commvault.com), it is mentioned under Considerations the following point:
  • You can only perform a live browse or restore operation for files on guest VM RAID-5 volumes from a backup copy. File restores for RAID-5 volumes are not supported from a snap copy.
Can you please elaborate a bit this sentence?
Does it mean that we cannot perform file restore with backup of vSAN datastore if we do not have a backup copy? Why RAID-5 volumes?
Thanks & Regards
Best answer by Orazan
Good afternoon.  You can not  do it from the Snap Copy. You would need to backup copy it if RAID-5 Volumes are in use. as to why that is the case i have no idea but will try to find some answers as to the why.  I will update this thread once I have some information.
Forum|alt.badge.img+18
  • March 31, 2022
  • April 1, 2022
Many thanks @Orazan for your answer.
It means that if the volumes are NOT configured in RAID-5 you can do a restore of files from a snap copy. Correct?
Indeed, it would be interesting to know why we cannot do it with RAID-5 volumes.
Many thanks for your investigations.
  • April 12, 2022
Hello @Orazan , Any information about why “You can only perform a live browse or restore operation for files on guest VM RAID-5 volumes from a backup copy. File restores for RAID-5 volumes are not supported from a snap copy.”
Many thanks
Regards
  • July 15, 2022
 I can not say for sure why we could not code this to be supported.  I would imagine it is related to the read operation that we would have to perform against the volume from the snapshot.
