Hi! Wondering if it is possible to have a remote Commserve used in a Livesync configuation communicate back to the initial Commserve via a deployed Network Gateway or Network Proxy Appliance? All agents, media agents at site will use the Network Gateway but is it possible for the remote Commserve to communicate through it as well?
Yes.
Getting it to work would require some creativity initially as you would have to create the configuration first and then apply the firewall definitions manually on the other side of the gateway.
I will elaborate later on my alt account : @christopherlecky
Thanks! Looking forward to details!
