MediaAgent Migaration
  • July 28, 2023
  • 152 views
Hello Team,
Please help, I’m planning to migrate MA (windows) with following steps.
1.Launch new server with installing MA software. and assigning same hostname ,new IP address.
2.Detach all mount path drives and DDB drives, attach the same in new server
3.Disconnect old server from the network.
4.check all services and process running on new MA
5.Map the respective LUNs, ( DDBs, Index Cache, Library) also make sure you are using the same drive letters while moving the contents on new server.
Is this method good to move forward , if any other steps please suggest.
Samuel
