Multi Factor Authentication (MFA) Flaw
  • May 18, 2021
  • 29 replies
  • 2817 views
Show first post
Mohit Chordia
Explorer
@dude :
Already did few months back they don't have any way apart from modifying the email template .
  • December 13, 2021
TFA email can be disabled using this Additional settings. If set at commcell level, it will disable for all the users that belongs to the commcell.
Category: CommServDB.Console
Type: Boolean
value: true
@Mohit Chordia , if you open a support case, share it here and I’ll split your query into its own thread.
Mohit Chordia
Explorer
Type: Boolean
value: true
@Nipa
Thank you . This is working.
