Recently moved Netapp away from direct dumping to Quantum tape library over FC to leverage CIFS / NFS.
Netapp cluster MGMT is on x.x.8.6
NDMP client is configured with x.x.8.6 TCP port 10000
Netapp has ICL’s in x.x.12.x/24
MA has 10GB teamed nic in x.x.12.x/24 and a nic in x.x.8.x/24
Client preview completes and can browse volumes and files with the NDMP client no issue at all, when kicking off the backup it goes over the 1G e0M cluster mgmt network as apposed to the ICL network on 10G.
- Tried adding dips to the MA properties to only talk on x.x.12.x/24 between MA and Netapp Filer
- Opened additional listening ports the MA in network properties at the client group level though (multiple MA across DC’s)
- When the backup is running, I can TNC (telnet) from MA to the ICL and it completes the connection on 10000
- Can ping from the ICL LIF back to the MA x.x.12.x IP’s no problem
Can not for the life of me get this working and is now bugging me for the last 4 days…
NDMP dumping to tape was working fine, but no longer fit for purpose as were taking weeks to complete a full dump (due to in place BOWs).
Everything works but sending data through e0M (cluster mgmt) (backup request originating port).
