Does a openstack vm with some external NFS mount can be backed up using while taking vm backup.
You should be able to backup Openstack with an external NFS mounts.
https://documentation.commvault.com/2022e/essential/121687_openstack.html
No exactly answered my question.
My openstack vm is having NFS mount. Can I backup this NFS share attached to VM directly from the hypervisor using vm snapshot. or do I need to install agent on VM to backup this external NFS mount
