Error Code: [18:183]
Description: Failed with Oracle DB/RMAN error [RMAN-03009: failure of backup command on ch1 channel at 12/04/2023 05:03:31 RMAN-10038: database session for channel ch1 terminated unexpectedly RMAN-03009: failure of backup command on ch2 channel at 12/04/2023 05:03:31 RMAN-10038: database session for channel ch2 terminated unexpectedly ]
Source, Process: ClOraAgent
+1
Hello
Thanks for the question, can you please advise the OS you are using? There is a known issue with windows server 2003.
Can you confirm the Commvault version you are running? There is a hotfix for a similar issue that was released in F28.32
Can you please confirm the Oracle version?
Kind regards
Albert Williams
+1
Good afternoon.
See information below.
- Client OS version: Oracle Linux Server 7.9
- Commvault version : 11.32.20
- Commserve OS version: Windows Server 2019
Kind Regards,
Tshepo Chiloane
