Hello Commvault Community,
We have an environment that is based on several data centers in different locations around the world. Aux Copy performs correctly and on the fly, while I would like to ask if there is any way to speed up this process? The situation is as follows:
In general, latency between sites is generally high, about 25-30ms, throughput is somewhere between 20-50gb/hr for AuxCopy jobs, sometimes faster. Is it not possible to split such AuxCopy into more minor sub-jobs? If more streams are used in parallel, latency will be less of a problem.
We have already studied the topic of Scalable Resource Allocation, but here this Batch Size will not help us, because here isn’t a large number of jobs to be copied and we are concerned only with improving the performance of this process.
Thank you in advance for your help on this topic.
Kind Regards
Kamil
