PowerBI to Commvault Integration
  • August 5, 2022
  • 11 replies
  • 1707 views
Need assistance on how do we integrate POWERBI with Commvault for custom reporting.
Hi @Pratik Chaudhari !  Thanks for the thread.
After reading your pm, I remembered that we had a topic for this, and got some good responses from our reporting documentation master:
The short version is that we mostly have access to the database locked down, but you can use APIs to get the data (and the how-to is covered in the above thread).
Take a look and let me know if you have any questions.
christopherlecky
Challenger
Forum|alt.badge.img+21
I’m going to resurrect this for selfish purposes.
I am attempting to use commvault report data to import to powerbi and the question I have is what Key should I use?
Is there a way to generate a semi-permanent api key so I can do refreshes against the report dataset?
Essentially I am making environmental changes and if I can get this work, I can get close to real time updates on the progress of the changes I am making.
Thanks.
Chris.
@christopherlecky , I found the thread this was discussed (and answered by dev):
I can’t tell you WHEN it will be out, but his reply is in the thread above.
christopherlecky
Challenger
Awesome, I will see what I need to do to track it.
christopherlecky
Challenger
@Pratik Chaudhari ,
I now understand the issue that you are running into.
The important thing to understand is that what is being returned by the rest api is a dataset.
You then have to parse the dataset in Powerbi
I have to do the same thing, once I figure it out I will make a howto post.
In the interim you may find this useful
Thanks.
Chris.
Before 5 years when such requirement came to me, I just added the Power BI user ID to Commvault’s DB security logins. Created the required report template in BI and it started populating those reports that are required
  • January 6, 2023
@Ramkumar Giridaran Can you please elaborate steps to achieve this?
  • March 27, 2023
@Ramkumar Giridaran Please do provide steps on how to go about integration to commvault?
  • March 27, 2023
@Uchenna Upgrade Commserve to 11.30 (2023) and use rest api datasets to connect with Commvault reports using AuthToken
  • March 27, 2023
@SGMak thank you for your feedback.
However, I am on the dataset rest api
How do I proceed from here?
  • March 27, 2023
@Uchenna
Please follow the BOL:
Datasets:
https://documentation.commvault.com/2023/essential/115048_rest_apis_for_reports.html
Create Acceess token: https://documentation.commvault.com/2023/essential/153488_access_tokens_for_rest_apis_01.html
