Last week we upgrade OS from 2012 to 2022 with SQl 2019. And now i see that one of the user cannot qlogin on another client to run a script. Its saying that username or passwoord invaled. But with the same user i can log in on webinterface or command center.
EvSecurityMgr::userLogin() - Socket e0x00000000000019AC]: LOGIN ERROR: Invalid login/password attempt with UserName
With another user can i have no probleem to qlogin
Now i want to create a new user but i need change from normaal password to Strong Paswoord -ps. Any idee how i do it?
Hi @Egor Skepko.
On the CommServe there is a qsdk.log - might be worth seeing what is printed there when the login fails for the remote client/user. CVD.log on the Commserve may have something too.
The OS upgrade should not have had any impact - but its strange that it correlates. Did you upgrade the Commvault version as the same time ?
@Damian Andre in the qsdk.log i see only:
LoginRequestWorker::DoWork k11098]  Processing Login request received for usersxxxxx] from hostName mxxxxx] isGuidBasedSession:otrue]
14668 2060  04/26 06:09:31 ---  CSConnection::ActUserLogin Lxxxxxx:19 ]   QSDK error received: e329]
14668 2060  04/26 06:09:31 ---  CSConnection::Login nxxxxx:19 ]  Login failure for User:xxxxxx for CommServer: xxxxx
14668 2060  04/26 06:09:31 ---  LoginRequestWorker::SessionLogin e11098]  Login to CommServer failed with error 329
On CVD log nothing to find.
Maybe the passwoord not meet the requiments? If i make a new passwoord how can i get string of Passwoord Strong ?
This is working again, i dont know but user can qlogin again.
