Qlogin not working after OS upgrade
  • April 25, 2023
  • 611 views
Last week we upgrade OS from 2012 to 2022 with SQl 2019. And now i see that one of the user cannot qlogin on another client to run a script. Its saying that username or passwoord invaled. But with the same user i can log in on webinterface or command center.
EvSecurityMgr::userLogin() - Socket [0x00000000000019AC]: LOGIN ERROR: Invalid login/password attempt with UserName
With another user can i have no probleem to qlogin
Now i want to create a new user but i need change from normaal password to Strong Paswoord -ps. Any idee how i do it?
Best answer by Damian Andre
Hi @Egor Skepko.
On the CommServe there is a qsdk.log - might be worth seeing what is printed there when the login fails for the remote client/user. CVD.log on the Commserve may have something too.
The OS upgrade should not have had any impact - but its strange that it correlates. Did you upgrade the Commvault version as the same time ?
  • April 26, 2023
Hi @Egor Skepko.
  • Challenger
  • April 26, 2023
@Damian Andre in the qsdk.log i see only:
LoginRequestWorker::DoWork [11098]  Processing Login request received for user[xxxxx] from hostName [xxxxx] isGuidBasedSession:[true]
14668 2060  04/26 06:09:31 ---  CSConnection::ActUserLogin [xxxxxx:19 ]   QSDK error received: [329]
14668 2060  04/26 06:09:31 ---  CSConnection::Login [xxxxx:19 ]  Login failure for User:xxxxxx for CommServer: xxxxx
14668 2060  04/26 06:09:31 ---  LoginRequestWorker::SessionLogin [11098]  Login to CommServer failed with error 329
On CVD log nothing to find.
Maybe the passwoord not meet the requiments? If i make a new passwoord how can i get string of Passwoord Strong ?
  • Challenger
  • May 2, 2023
This is working again, i dont know but user can qlogin again.
