reassign media tape to another commcell
  • 30 August 2023
  • 48 views
I have some tapes not assigned to the good commcell, do to librairie with different partition.
How can I remove the tape from commcell 1 and assign this tape to commcell 2 ?
Regards
Alexandre
Hi @Alexandre.C ,
Good day!
Have you shared the TL across two commcell?
If not, then make sure the tape hasn’t written data via commcell 1 then you can load the media on the TL that present on the commcell 2.
Hi Arunkumar,
I have 1 librairie with 2 partitions and only LTO8 drive
p1: for commcell 1 with tape in 100XXXXX label
p2: for commcell 2 with tape in 200XXXXX label
a mistake was done when someone insert tape with 100XXXXX into the partition 2.
Commault has already used these tapes but now the retention of these tapes is over.
So I just want to delete tape association of Commcell 2 and insert this tape into the partition 1 and hope commcell one detect new tape dor default scratch and not with this issue : “Media belongs to a different CommCell.”
Hi @Alexandre.C ,
Good day!
If the jobs are aged on the tape then you can insert the tape to partition 1 and start using it which will be detected as a scratch tape only.
