Recover data from tape without CommVault instance
  • 3 July 2024
  • 37 views
Hello Everyone,
Is it possible to recover data from a tape that was used in a previous CV instance?
For example, data was previously backed up to tape using CV instance.  Then a few years later that CV instance was uninstalled and no longer exists.
Is there a way to recover data from that tape using any CV tools?
Thanks for any information
Maybe try a Tape Catalog and Merge operation
https://documentation.commvault.com/2023e/expert/recovering_aged_data_getting_started.html
@Ian G I think it should be possible using tape cataloging.
https://documentation.commvault.com/2022e/expert/cataloging_tape.html
