Redundant network gateways?
  • 3 April 2023
  • 90 views
Badge +6
Is it possible to have more than one Network Gateway to the same zone in a Commvault deployment? Obviously know can have multiple gateways that are used to access multiple security zones but is it possible to have multiple gateways to the same zone in a redundant configuration?
Best answer by Damian Andre 3 April 2023, 08:59
Yes, Commvault supports multiple ‘routes’ for redundancy. It has code to select the best route. So you have have network topologies that are using multiple gateways to provide redundancy. What isn't support is doing something like putting a load balancer in-front multiple proxies/gateways - that wont work.
