Hi guys ,
is there a report/graphic which tells you how many jobs, sub-client or stream running divided by hour?
for example from 20 to 23 how many jobs, sub-clinet or stream were running.
Best answer by Stuart Painter
View originalHi guys ,
View originalHi
I don’t believe we have any built-in report or any on Commvault Store that shows jobs per hour.
To achieve this with the currently available reports, you would have to run Backup Job Summary Report for each hour you are focussing on and potentially consolidate the result sets separately in Excel, for example.
If you could elaborate on the request, we may be able to raise this with Development and submit an enhancement request for such a report in the future.
Stuart
