restore from edge drive error
  • 7 September 2023
  • 91 views
I cant restor frome edge drive with this error message.
Cannot start restore program on host Server_Name*Server_Name*8400*8402*] - a network error occurred or the product's services are not running.
Source: ma-servername, Process: fsIndexedRestore
can you help me to  resolve this probleme?
this is just a poc, i don’t have a support licence to open a SR with commvault support.
Regards.
Hello @Elmahdi Achraf
Is check readiness passing for this media ma-servername ? Please navigate to client computers > Right click on this MA > All task > Check readiness.
Please confirm the communication from the destination client machine is working with  ma-servername and vice versa? Please check cvping, ping, nslookup, telnet (8400, 8403)
Best,
Rajiv Singal
I have thoroughly reviewed the communication between the media agent and the client, and everything appears to be functioning correctly. The readiness check has also passed successfully. I have included the screenshots for reference.
Elmahdi Achraf
The screenshot has one sided communication. Could you confirm if the other side communication is working as well? Please also attempt to run a restore with same source and destination if possible.
 Also, can you try to restore using commserve as the media agent? It should run a Index restore job soon as you browse the data and that would narrow things down for us.
Best,
Rajiv Singal
The problem was a conflict between two instances using the same ports on the same server.
Hi @Elmahdi Achraf,
i got the same error, can you share me more details ?
i only got the issue when i tried to restore files from cloud (aux copy).
Best regards,
NAT
