Restoring database instancje (pg, mysql) using cvpysdk in python
  • Apr 10, 2024 11:56 AM UTC
  • 85 views
hello :),
I want to restore an instance of my database using Python.
I'm trying to use the cvpysdk library.
I can use:
https://github.com/Commvault/cvpysdk
>>> job = subclient.restore_out_of_place(client, destination_path, paths, overwrite, restore_data_and_acl)
should I use another way?
br
k2
Hello @AleAle
I would recommend using the following for details around Python commands:
https://api.commvault.com/
For example this might be what you are looking for:
https://api.commvault.com/docs/SP34/api/cv/MySQLDatabases/my-sql-restore#mysql-restore-operations
On the right hand side you can select language and we have a Python section:
Example:
Kind regards
Albert Williams
  • May 10, 2024 2:30 PM UTC
thx, I handled with cvpysdk.
br
K2
Hello @AleAle
That’s good news you have got it working.
Can you please mark the thread as answered if there are no further questions.
Kind regards
Albert Williams
