Retain jobs with Qoperation
  • March 8, 2022
  • 143 views
Forum|alt.badge.img+5
Hi Team,
Do we have any command to extend the retention for multiple jobs at a time. We have the task to extend the retention of multiple jobs (like 100 jobs) and is there any easy we can do it.
Best answer by Mike Struening
@naraharsha , we don’t have a script on hand, though this doc should help you create one:
https://docs.microsoft.com/en-us/powershell/module/microsoft.powershell.core/about/about_foreach?view=powershell-7.2
Forum|alt.badge.img+20
  • Challenger
  • March 8, 2022
Hi @naraharsha ,
Honestly I do not know, but I would be interested to read the means to do it, if any.
Do you need to do it for like 100 jobs and for all copies of each job ?
Or for only one copy of each job ?
Laurent.
  • March 8, 2022
@Laurent
I want it for jobs which are in one copy only.
  • March 8, 2022
Hello @naraharsha,
Please refer to the following documentation:
https://documentation.commvault.com/11.24/expert/11409_qoperation_jobretention.html
This will only do one job at a time, but you should be able to use a foreach loop in powershell to iterate through an input file which lists all of the jobs that you need to extend the retention for.
  • March 9, 2022
@blistwan Thankyou.
Is there a powershell script to automate this work by using foreach loop?
