RMAN Script Warning
  • April 18, 2023
  • 1246 views
antonio
Explorer
Hello everyone,
I’m backing up an Oracle database in Linux, and every time a backup of this database runs I received the Error below:
Error Code: [18:183]
Description: Failed with Oracle DB/RMAN error [RMAN-06554: WARNING: file 10 is in backup mode RMAN-06554: WARNING: file 11 is in backup mode RMAN-06554: WARNING: file 14 is in backup mode RMAN-06554: WARNING: file 15 is in backup mode RMAN-06554: WARNING: file 16 is in backup mode RMAN-06554: WARNING: file 17 is in backup mode RMAN-06554: WARNING: file 18 is in backup mode RMAN-06554: WARNING: file 19 is in backup mode RMAN-06554: WARNING: file 20 is in backup mode RMAN-06554: WARNING: file 21 is in backup mode RMAN-06554: WARNING: file 33 is in backup mode RMAN-06554: WARNING: file 34 is in backup mode RMAN-06554: WARNING: file 35 is in backup mode RMAN-06554: WARNING: file 36 is in backup mode RMAN-06554: WARNING: file 37 is in backup mode RMAN-06554: WARNING: file 38 is in backup mode RMAN-06554: WARNING: file 40 is in backup mode RMAN-06554: WARNING: file 41 is in backup mode RMAN-06554: WARNING: file 43 is in backup mode RMAN-06554: WARNING: file 44 is in backup mode RMAN-06554: WARNING: file 45 is in backup mode RM
Is there something I can do in Commvault side? If no, what could I say to the DBA to help me out fix this error and get the backup working without errors?
Best answer by Gowri Shankar
Hi @antonio
The DBA might have placed the DB in backup mode and to perform a online backup we dont need to db to be in backup mode.
The DBA needs to verify if there is any other backup running outside commvault & end the backup mode.
Provide the following article so the DBA could verify and end the backup mode
https://oraclespin.com/2010/10/31/alter-database-beginend-backup/
Let us know in case of any other questions.
Gowri Shankar
Forum|alt.badge.img+16
  • April 18, 2023
Hi @antonio
Gowri Shankar
antonio
Explorer
  • April 18, 2023
Hello @Gowri Shankar
I will ask the DBA to check this, as soon as I have his answer, I’ll come back here.
Thanks.
antonio
Explorer
  • April 26, 2023
Hi @Gowri Shankar
The solution you provided worked like a charm. I will mark your reply as the solution.
Thank you for the help, 😊
Antonio.
