running qscript on Linux Commserve host
  • Jan 2, 2024 2:44 PM UTC
  • 369 views
Forum|alt.badge.img+5
I’m trying to run a qscript on my linux Commserve in 11.34.3 and i get this error :
[root@redhatcs01 Base]# ./qoperation execscript -sn GetClient_Info.sql
execscript: Error 0x13b: Qscript execution failed.
QScript[GetClient_Info] CS[commrhelcs01] DB[CommServ]
Qscript Output:
Failed at RunStringQuery_QS! Error: [Failed to execute SQL Script!].
if anyone have information about using qscript on Linux Commserve ?
Kind regards,
Christophe
PS : Happy new year 2024 !!🥂
Best answer by ChrisCC
i have found why i can’t run script in my linux CS (11.34.3 in a test lab with NFR license).
I have installed the sqlcmd tools to manage sql but they have changed some paths in sql server.
Fortunately i have taked a snapshot on my VM before installing the sqlcmd tools.
once i revert from the snapshot the qscript work fine.
regards,
Scott Moseman
Forum|alt.badge.img+23
I was able to run the script successfully against a Linux CS.
[root@cv-client-1 Base]# ./qlogin
Enter User Name : admin
Password :
User logged in successfully.
[root@cv-client-1 Base]# ./qoperation execscript -sn GetClient_Info.sql
QScript[GetClient_Info] CS[cv-commserve-1] DB[CommServ]
Qscript Output:
Name    Host Name       OS      ACTIVE
cv-commserve-1  cv-commserve-1  Linux   YES
cv-client-1     cv-client-1     Linux   YES
Qscript Execution Succeeded!
Scott
  • Jan 3, 2024 9:20 AM UTC
Hello Scott,
thank you for your feedback.
My commserve was hardened with selinux enable, do you use an hardened CS ?
regards,
  • Jan 3, 2024 10:59 AM UTC
regards,
