Schedule Policy for Restore Job
  • November 15, 2023
  • 138 views
Is there a schedule policy for restoration?
Best answer by Navneet Singh
@RlpCVVnt
From the schedule policy there is no option but you can try the below if this helps:
https://documentation.commvault.com/2022e/expert/6646_scheduling_advanced.html#schedule-restore-by-jobs
Forum|alt.badge.img+13
  • November 15, 2023
@RlpCVVnt
SparshGupta
  • November 15, 2023
Hi @RlpCVVnt
What agent are you looking for?
If the intention is to schedule restore, you can consider exploring periodic / continuous replication options as well.
https://documentation.commvault.com/11.24/essential/113647_disaster_recovery_and_replication.html
Sparsh
Onno van den Berg
Forum|alt.badge.img+24
@RlpCVVnt through the CommCell console you upon initiating the restore also choose to schedule the restore via a schedule. this schedule can be found under the schedules at CommCell level.
Currently you cannot do this from Command Center, however I do know it is expected to arrive soon for databases.
  • November 16, 2023
Hi Guys appreciate your responses. Will try first the schedule option upon the restoration process and see if this will work for me. Thank you!
