Set "Throttle RMAN disk read (MB/Sec)" for Oracle IntelliSnap Backup
Badge +1
How set "Throttle RMAN disk read (MB/Sec)" parameter for "RMAN Backup Copy" using "Proxy Server" operation?
If I setting "Throttle RMAN disk read (MB/Sec)" for schedule under subclient which using IntelliSNAP it not take effect.
Badge
Please change the value of this PARAMETER under the sub-Client of Proxy Host.
Badge +1
We use cluster group client for source and proxy clients. Also this PARAMETER change on schedule or scheduler policy but we dont have schedule or scheduler policy under the sub-Client of Proxy Host.
Badge
Please try it on the Cluster Client Group of the Proxy. It is sub-client level parameter. You do not need to add it under the Schedule or Schedule Policy.
Badge +1
 I can’t find this parameter in Sublient porperties tabs
 but it located on Oracle Options tab when i run backup or create schedule for subclient
I also set an additional parameter nORA_BKP_RMAN_RATE_IN_MB at the client computer level for both Cluster Client Group members, but this also does not affect the ALLOCATE CHANNEL command.
Badge
Can you please open a Support Request and share that SR number, I will investigate it.
Badge +1
Sorry we don't have a support contract at the moment..
