SQL DB restoration from SQL 2016 to sql 2012
  • April 19, 2023
  • 7 replies
  • 661 views
Hi Team,
Greetings!
is SQL DB restoration can be done from a DB hosted in SQL 2016  to SQL 2012 ?
I hope it will work as higher version to lower version restore, could someone confirm it.
Best answer by Ledoesp
I think the note from Microsoft makes reference to any type of database, user or system.
If you search there are many queries related with this specific topic in Internet.
Additionally this is documented here:
https://documentation.commvault.com/2022e/expert/61536_sql_restore_options_general.html
Note: SQL Server databases can be restored to servers with similar or higher SQL Server versions installed on it.
  • April 19, 2023
from the MSSQL vendor: https://learn.microsoft.com/en-us/sql/t-sql/statements/restore-statements-transact-sql?view=sql-server-2016
 Note: No SQL Server backup can be restored to an earlier version of SQL Server than the version on which the backup was created.
  • Challenger
  • April 19, 2023
Thanks Ledoesp but we used to do restore earlier and it is changed something newly, I read the document and it says Backups of mastermodel and msdb that were created by using an earlier version of SQL Server cannot be restored by SQL Server. and we are trying to restore a user created DB. will that wont work ?
  • Challenger
  • April 19, 2023
just had a chat with commvault chat support and they said restore will work from SQL 2016  to SQL 2012 but they dont have any document which is stating the statement. little confused now. will wait for your update ledoesp.
  • April 19, 2023
  • Challenger
  • April 19, 2023
oh that means it can be restored from sql 2012 to sql 2016 but not sql 2016 to 2012 ? am i correct.
  • April 19, 2023
you are correct. to higher version yes but not to lower version
  • Challenger
  • April 19, 2023
Thanks Mate!
