Sql - vm - restoration with independent disk
  • May 1, 2023
  • 163 views
Forum|alt.badge.img+16
i would like to know what is the best way to backup and restore the sql vm which has intendant disk
backup -
type 1 - vm level backup - in this the independent disk is not included
type 2 -File system level backup
type 3 - database full backup
type 4 - archive backup
if i have a situation where my whole environment is affected what is  the restoration procedure
first vm restore
then file system level restore
then db full restore
then archive restore
this will take hours and hours to complete , is there anyway i can take the backup and restore effectively by reducing down time
can someone help me please
Best answer by Zubair Ahmed Sharief
Hello @Ajal
It would be good to know why the disk was marked as independent, based on this you can determine if a backup was required for this disk.
Without independent disks, VM restore would be the fastest way to bring up the server.
With independent disks, backup and restore would be more than just VM restore (additional recovery required for complete recovery)
I would test the backup and recovery of whatever option selected before implementing it in production.
Emils
  • May 2, 2023
Hi @Ajal
Thanks for reaching out
I would suggest to configure SQL with Appaware VMware Backups.
Please review our documentation for further information, it covers both backup & restore.
  • May 2, 2023
@Emils  Hello Emils , will it cover the independent disk?
Emils
  • May 3, 2023
Hello @Ajal
