Synthetic Full is not running based on automatic schedule settings
  • March 21, 2022
  • 9 replies
  • 351 views
We have a Schedule Policy for Linux clients with two tasks: one for Incremental and one for Synthetic Full based on automatic schedule settings.
We noticed that Synthetic Full is running once per week.
Best answer by Robert Horowski
There are additional rules that can trigger an automatic SFull.
Please check if one of these rules apply to your environment
https://documentation.commvault.com/11.25/essential/130560_automatic_server_plan_backup_schedules_and_associated_conversion_rules.html
if so that would explain why SFull is running more often then you expect.
byates
  • March 21, 2022
Hello Eduardo,
Did you make any changes or upgrades in December?  It appears it was working correctly until then.
Robert Horowski
Hello @Eduardo Braga
as @byates already asked did you upgrade your system around 12/7/2021?
Also did you change anything related to retention or secondary copies (are there any?) in SP assigned to this subclient around that time?
  • March 22, 2022
Hello Eduardo,
I upgraded Commvault in December.
@Eduardo Braga , what did you upgrade from and to?
This definitely sounds like something you should bring to Customer Support via an incident.
Can you create one and share the case number with us?
@Eduardo Braga , following up on this, I do not see any open support cases.  Were you able to find a solution on your end?
  • April 23, 2022
Hi, Mike, I can’t open a support case right now. Our contract with Commvault will be renewed soonIn the last week what I tried to do was create a new schedule policy, but I didn’t work. The CVLT continues to initiate a Synthetic Full Job per week.
Understood.  I’ll follow up occasionally to see if you’ve renewed maintenance and opened a case.
  • April 25, 2022
@Eduardo Braga, Automatic Schedule jobs are usually initiated by the client(s), though I think in the case of SynthFulls it’s on the MA. If you check cvd.log and/or osc.log on the MA at the time when the backup started, it may give some insight as to what’s happening.
Robert Horowski
  • Community All Star
  • April 28, 2022
