tape drive utlization , lt09 - compression not working due to encryption
  • 12 February 2024
  • 10 replies
  • 49 views
Userlevel 1
Badge +13
hi ,
we have hyperscale with encryption enabled and we are having aux copy to tape with below settings
basically each tape should give aroung 40 tb after compression but we are only getting 15 tb  , do we need to disabled the encryption .
i can see hardware encryption is enabled in the data path setting for tap e
Userlevel 2
Badge +8
Hi Ajal,
Encryption is important for data security. If you wish to disable it , you can. But disabling encryption will not be helping us as this is not deduplication data (Tape does not support deduplication).
We would recomend you to enable hardware compression (if not already enabled) if your tape vendor supports it.
Configuring Hardware Compression (commvault.com)
Further can you please help us understand how are we reaching 40TB figure as expectation ?
Suleman
Userlevel 1
Badge +13
@SMD  hardware encryption is already in place ,
now we compression enabled for DDb enginer by default, so when we are using software encryption hardware encryption will not work for aux copy right?
for lt09 for uncompressed data 40tb space
Userlevel 1
Badge +13
@SMD  will this work , disabling the compression from the below option
and make sure hardware encryption is enabled
this way we can get the expected utlization right ?
Userlevel 2
Badge +8
Hi @Ajal
You are on a deduplicated copy property.  We can disable the below option if it is from tape copy.
Also, can you please confirm if this is true for Tape with encryption enabled ?
Idea is to make sure we use Hardware encryption ,hardware compression and let Tape library take care of the rest.
Suleman
Userlevel 1
Badge +13
@SMD i dont know what you meant below
the screenshot was of ddb engine property
if i disabled this software compression will stop that way hardware compression can work
Userlevel 2
Badge +8
@Ajal  Tape copy and Deduplication copy is different. Also if we have software and Hardware compression/encryption selected, system will always prefer hardware.
We can make chnage on teh Tape copy, not on the deduplication copy.
Suleman
Userlevel 1
Badge +13
@SMD  may b you didnt understand,
i have hyperscal pool and i have create aux copy from it to tape,”.
I can see in the document if software encryption enable in source hardware encryption may not work
may be you dont have information about this
thanks
Userlevel 2
Badge +8
Hi @Ajai,
Apologies for the confusion.
If software encryption is enabled on the source, we can enable hardware encryption for the AUX and keep software encryption disabled. This will work.
Suleman
Userlevel 1
Badge +13
@SMD
what about below ,
  • If you are performing an auxiliary copy operation to tape and the source copy has software compression enabled, you will not see any benefit from hardware compression.
for hardware level compression to work , source copy has to plain and un compress state
Userlevel 2
Badge +8
Hi @Ajai
I went trhought the notes now
Notes
  • If deduplication is enabled on the source copy and the copy uses software compression, there will be no saving from hardware compression on an auxiliary copy to tape. This is because the data has already been compressed on the source copy.
  • Software encryption will eliminate any hardware compression. Do not use software encryption when you enable or expect hardware compression of the data.
ref: Use Tape Drive Compression to Save Storage Space (commvault.com)
Here is no mention about encryption on the source copy must be disbaled but speaks about source copy should not have software compression enabled. We can disable software compression on source copy and monitor the outcome.
Suleman
