Timeout for PreBackup or PostBackup process
  • March 24, 2023
  • 413 views
I’m looking for a way to set a timeout for PreBackup and PostBackup process.
My expectation was a default timeout of 600 seconds. Therefore I created a batch script which has a wait of 700 seconds included. Commvault was patiently waiting for the script to finish, but I would like to have a timeout after which Commvault fails the job.
Does anybody know a way to set such a timeout? I could not find any hint on this and also no additional setting.
Best answer by Scott Reynolds
Hello @Marc St.
I do not think there is a timeout setting that can be entered within Commvault. However if you can modify the script to return a non-zero error after 600 seconds or whatever time and use the following additional setting it will force the job to fail.
https://documentation.commvault.com/additionalsetting/details?name=JMFailJobOnScriptFailure
Hello @Marc St.
  • March 28, 2023
Hello @Marc St.
Thank you Scott.
