unix filesystem corruption
  • October 13, 2022
  • 89 views
Will Commvault agent identify any filesystem corruption, when it tries to backup a unix filesystem or just ignore it and move to next filesystem ?
Best answer by Gowri Shankar
Hi @gandhikarthi
Thats expected, if OS cant see the files even the backup will not see that files.
Forum|alt.badge.img+16
Hi @gandhikarthi
It really depends on multiple factors like file system in use etc.
In most cases the read operation will skip and continue when it runs into a soft error but the job may either hang or go into pending if its a hard I/O error.
You may view the reason for skip from commvault console backup history right click on the job and view failed / skipped items.
Gowri Shankar
SparshGupta
  • October 14, 2022
Hey @gandhikarthi
When you say filesystem corruption, what exactly is the corruption here? And what’s your expectation here?
Sparsh
  • October 14, 2022
One of the filesystem was corrupted and the mount point looked like empty folder. But didn’t see any error during the backup.
  • October 18, 2022
Hi @gandhikarthi
