upgrade commserve from 11.30 to 11.32
  • 28 February 2024
  • 77 views
Badge +6
Hello
I have CS in 11.30.23 and MA in 11.30.52 (they both physical servers - windows 2012R2)
and I want to upgrade to 11.32 version
and the SQL you can see in the image that I attach below:
Can I do the upgrade directly ?
or maybe I need to upgrade the windows from 2012R2 to windows 2016?
Thank you very much :)
Best answer by Chris Hollis 29 February 2024, 04:13
Windows 2012 is no longer supported in 11.32 as the OS for Commserve.
https://documentation.commvault.com/2023e/expert/commserve_server_system_requirements_windows_02.html
Even if it was… there is no reason for leaving the most important part of the cell on unsupported OS. OS update is more than recommended here.
Badge +6
Hello @Jacek Piechucki  , thank you
I know - so I need to upgrade to windows 2016 and then upgrade the CS to 11.32 ?
Thanks !
I would say yes - plan either the OS upgrade or hardware refresh. Sometimes the second option is less time consuming and you have 3 in 1: OS, SQL and CV updated.
Badge +6
OK , but if I will upgrade the OS and after that I will upgrade the CS, the SQL will update  automatically in the CS upgrade ?
BR
Badge +15
@ariel_b
No, you are running SQL 2016 which is compatabile with FR32 so you won’t be prompted. We have a workflow you can run to upgrade the Commserve SQL Engine.
Please check this out: https://documentation.commvault.com/2023e/essential/upgrading_microsoft_sql_server_editions_on_commserve_computer.html and this: https://documentation.commvault.com/2023e/essential/running_sql_edition_upgrade_workflow.html
Regards,​​​​​​​
Chris
