Using Commserve LiveSync optoin - Commvault Clients is showing Commserve or gateway hostname is active node
  • 12 August 2023
  • 27 views
Badge +4
Hello Team,
Our environment we are using two Commserve active/standby with livesync feature. The commserve using DNS floating option for common name.
The clients are showing Commserve or Gateway hostname is active node instead of common Commserve name.
While performing failover to another commserve will get another active host name.
Is it will change manually in all the clients or any options to modify.
Please advise.
