Web Exception generated [400] [BadRequest] [BadRequest] [Parameter 'DeltaToken' not supported for this request.]
  • April 17, 2023
  • 283 views
Commvault Version 11.28.56
since April 5th, my O365 teams backup jobs have been finished with completed with one or more errors.
In the joblog I see the following error messages:
PerformWebRequest - Web Exception generated [500] [InternalServerError] [InternalServerError] [Failed to execute request.]
Is there a known issue?
Franz-Josef
Best answer by fjs63
FYI: There is currently a fix being created for this issue.
Forum|alt.badge.img+18
  • April 18, 2023
Good afternoon.  I would recommend opening a case with customer support to investigate this further.
  • April 20, 2023
Thanks for you reply. We have opened a case. Incident-Nr. 230420-274.
  • April 20, 2023
  • April 20, 2023
@fjs63 thank you for the update.  Can you please provide the case number?
  • April 20, 2023
Do you mean the partner case Number? AA00060534
