Hi, we’re going through our VM backups in regards to the VMs that fail to quiesce during snapshot operation. We can see a pattern where many of these VMs are running some Apache or IIS webserver.
I’m wondering if that might be due the webserver are running some kind of database that might be causing the issues? Maybe like SQL express or MySQL.
For regular and full blown SQL servers we disable the “SQL Server VSS writer” to stop the snapshot interfering with the SQL log backup chain and that normally solves the quiescing issue.
Anyone that has some insight to this perhaps? I would like to avoid using agent backup if possible.
