Customize standard repots
  • 27 October 2022
  • 76 views
Badge +4
I wanted to know if I can customize the default reports from Commvault. As an example the fall Behind Secondary Copies.
I find "10 days for critical" too much and would like to customize these benchmarks
Best answer by Mike Struening RETIRED 27 October 2022, 19:58
Hey @Base64 , hope all is well!
You can create your own report using CommCell Views or report data:
Both threads should help you with this project, though let me know if you have any questions!
