HyperScale Appliance/Reference Architecture Gluster Volume is reporting incorrect capacity
  • 5 January 2021
  • 0 replies
  • 612 views
Badge +4
Issue
  • There was a known issue identified with Redhat Gluster where the Capacity is reported incorrectly
  • This is due to an incorrect parameter on the Gluster known as shared-brick-count which will count how many bricks share a file system and how the disk space is divided accordingly (within the Gluster)
Methods:
  • Method 1 - if you are on the following Service Pack & Hot Fix Pack
    • SP15 & Hot Fix Pack 35
    • SP16 & Hot Fix Pack 27
    • SP17 & Hot Fix Pack 12
  • Method 2 - prior to the above Service Pack or Hot Fix Pack
IMPORTANT NOTE - this only needs to be done once and will be applied across the Gluster\, no further remediation is required.
Method 1
  • Commvault introduced an additional feature under (/opt/commvault/MediaAgent) which will generate the shared-brick-count script in (/usr/lib64/glusterfs/3.12.2/filter/) for all the nodes
  • Navigate to the following location
    • # cd /opt/commvault/MediaAgent
  • Execute the following script
    • # ./cvavahi.py fix_gluster_volsize
  • Then execute the following command (only on one node) and this should resolve the size mismatch
    • # gluster volume set (storage pool name) cluster.min-free-inodes 5%
  • On each of the HyperScale Nodes, log in and verify all the Bricks have "Shared-brick-count" set to "1" using the following command
    • # grep -r "shared-brick-count" /var/lib/glusterd/vols/HyperScale_Pool
  • Then re-run df -h and confirm that the volume shows the correct size.
Method 2
Do the following on all Nodes
    • # cd /usr/lib64/glusterfs/3.12.2/filter/
      • Note - You may need to create the 'filter' folder if it doesn't already exist.
      • Use the following command
        • # mkdir filter
  • Inside the ‘filter’ folder, create a file named “shared-brick-count.sh” and paste the following content to it :
    • # vi shared-brick-count.sh
  • Input the following content:
#!/bin/bash
sed -i -e 's/option shared-brick-count [0-9]*/option shared-brick-count 1/g' "$1"
  • Give execute permissions to the shared-brick-count.sh file on all nodes by executing the command
    • # chmod 755 shared-brick-count.sh
Do this on only 1 Node in the Gluster
  • Run the following command to force Gluster to update the volume. Run this on only one node.
    • # gluster volume set HyperScale_Pool cluster.min-free-inodes 5%
Verify the content
  • On each of the HyperScale Nodes login and verify all the Bricks have "Shared-brick-count" set to "1" using the following command
Be the first to reply!
