3 primary copy pool in 1 secondary copy pool - is this possible??
  • Jan 16, 2024 10:44 AM UTC
  • 68 views
I have 3 locations worldwide with different companies.
I want to back up these locations with a secondary copy of the backups at the main location in a storage pool.
Is this possible with an auxiliary copy?
or what is the best way to do this?
Best answer by mikevg
Hello @YvonneS,
Yes this is possible, in your plans you can browse to the backup destinations tab add a copy and select the storage pool you want to assign and other configurations like retention and done :)
  • Jan 16, 2024 12:28 PM UTC
Hello @YvonneS,
